Vellfire 3.5 LPG conversion with 92L tank
Just done this one, I didn't take many pics but I've posted a few I took below.
The owner is a member of a few Alphard / Vellfire forums but didn't fancy his chances with the usual recommendations after reading about the odd LPG problem from the usual Alphard/Vellfire recommended installers. He was advised to come to me by the owner of an Elgrand who told him I'd converted over 450 Elgrands and only ever had 2 small LPG problems... I'm in Yorkshire, one problem was in Truro Cornwall, the other problem was in Bristol, on separate occasions I drove to Truro and to Bristol to fix them on the customers doorsteps. I don't get many problems, which is why I can offer this kind of service.
Forget 'teething problems' and '1000 mile free checks' that are really just a get out of jail free card for installers who don't get things right in the first place, I get things right in the first place and fuel injection systems don't go out of tune all by themselves, appropriate and reliable parts don't often fail if fitted properly either. Should be able to have an LPG conversion and not have any troubles for 100000 miles, the owner should be able to change their own filter every year very easily.
Forget 'online servicing / tuning', there is no way someone at the other end of the internet can physically change any part of the install, they need to fit appropriate components and fit them properly then calibrate the resultant install properly, do all this correctly and it should not need any adjustments. Firms that offer systems that can be tuned over the internet are obfuscating the real situation, there are no LPG systems that specifically offer tuning over the internet, firms that offer this simply take advantage of Windows built in remote desktop software (using that you can use any software on anyone else's computer and we can all do that with any software) but some firms try to sell 'remote tuning' as a bonus...  In reality such firms have so many customers with systems they fitted that have problems that they have taken to 'tuning over the internet' to try to limit the number of customers they have returning to them with problems. They cannot really tune a vehicle remotely anyway, to tune a vehicle's LPG system the installer has to be sat in the car while it is being driven and preferably driving the vehicle themselves because it is difficult to try to explain to another driver that they need to hold the car at a certain engine load to try to keep petrol injector pulse duration at a given value, most drivers interpret this as meaning a certain road speed but it is not road speed they need to hold steady. If the installer isn't in the car and someone else is driving it they won't anticipate a lot of things... you can tell a driver to boot it but if the road conditions don't allow for booting it at that moment the driver (rightfully) won't boot it. Remote tuning at best allows a dodgy installer to guess where they went wrong and guess what changes to make, even if the results seem OK the calibration will be a mile away from correct compared to a proper job of calibration. I can easily spend half a day just properly calibrating a vehicle's LPG system but combined with well chosen correctly installed components the results speak for themselves. The results are why I have the confidence to tell customers I'll drive to them if they have any problems.
The LPG tank is fitted in the spare wheel location so it doesn't take up any interior space and is rated at 92 litres gross capacity. Usually LPG tanks only fill to 80% of gross capacity (net capacity is usually 80% of gross / rated capacity) but this one has net capacity of 90% of the 92 litre rated tank. This means that at 15degC it could be expected to have net capacity of just over 83 litres but in this cold weather it has net capacity of 88 litres... LPG expands and contracts with changing temperature and LPG is actually (behind the scenes) sold by weight not by volume, so in cold weather when LPG is more dense than in warm weather it will take more gas. Due to the big tank this Vellfire will have 100 miles more range on LPG than some Vellfires converted elsewhere.
The filling point is hidden behind the petrol filler door, this was the customer's choice, other options included all the usual (in the bodywork, in the wing, at the rear, fitted to a towbar, etc). The hidden filling point uses 16mm external threads and is very much stronger than the usual 10mm internal thread hidden filler, it also allows filling with LPG a bit quicker than the 10mm type.
A nice neat install that is technically correct, all appropriate and well suited to the vehicle components fitted and calibrated very well indeed. I don't fit the same LPG parts on every vehicle I convert... that would be like quite liking Holley carburettors and telling customers it would be a good idea to fit a Holley carb on their Chevy 5.7 V8 or their Mini.. Horses for courses and LPG components should be well suited to the vehicle. A lube system fitted (as should be fitted on anything Japanese).
  • Like 2
Link to comment
Share on other sites
  • 5 months later...
  • 5 weeks later...
I would be looking to convert a 3.5 Vellfire to LPG and found this review useful.
Savings would be quite significant especially with a larger engine.
Concealing the tank in the spare wheel bay as also a nice touch.
Link to comment
  Only 75 emoji are allowed.
 Share
