Does anyone know the specifications for wheel balancing please? 04 Alphard.
Hi Granny & Pop,
I've put the wheel alignment specifications in a post in the Technical Guides section - hope this is helpful.
I assume you want to check the wheel alignment, rather than just balance the wheels (to avoid vibration, steering wheel wobble at certain speeds...) Front wheels can be adjusted, rear axle is fixed.
Our Alphard also pulls to the left and I've been trying to work out what's causing it (as you'll see from the post...)
Regards,
pcous
