Windows opening a crack
Just had a flat battery. Now when I try closing my windows they close fully then open about an inch. I can't get them to stay closed! Any ideas what I can do? Toyota Alphard 2.4 2005
Thanks!
Edited by Robives
Corrected
Try this.
From the drivers side window key pad, fully lower each window one at a time and close it again.
Move to next window and repeat.
That should do it.
If you have an electric moon roof you may need to do the same with that.
Good Luck.
Thanks! I combined this with a post I found on YouTube. Starting with drivers window, open the window fully, hold the button down for 10 seconds. Close the window, hold the button up for 10 seconds. Repeat for the other windows with their own control. Windows now working normally. Thank you! Rob
