I would lke to know the rear Camber Angle please. Many thanks in anticipation.
Hi starider,
You've not said which model, but if it's helpful here are the wheel alignment figures I found for our 2002-07 Alphard:
MALAYSIA: TOYOTA ALPHARD MPV(2002 - 2007)
Parameter.         MIN MAX
Front Total Toe -0.11 0.11
FL Toe -0.06 0.06
FR Toe -0.06 0.06
FL Camber -0.41 1.25
FR Camber -0.41 1.25
Rear Total Toe 0.1 0.26
RL Toe 0.05 0.13
RR Toe 0.05 0.13
RL Camber -1.5 -0.58
RR Camber -1.5 -0.58
Left Caster 2.08 3.58
Right Caster 2.08 3.58
Regards
pcous
Very useful information, pcous.
Thank you.
Any of us experiencing uneven tyre wear may find a solution in this data.
It may help tyre fitters too, who often want to tweak the suspension geometry !
Or to get it corrected after they did !
  • 4 months later...
Hi all,
Correction - I've found an alternative set of wheel alignment figures for 2002-07 Alphard, which are different from those I posted in Oct 2021 (they were Malaysian and I can't see them on the website any longer....):
The link is:
http://www.jltechno.com/en/alignment_specs.php?brand=Toyota&ModelName=Alphard/Vellfire:H10%C2%A0Series:MNH10W&ModelID=610365
and jltechno also publish data for other Alphard models: http://www.jltechno.com/en/alignment-data-lookup/40016/Toyota.html
Alignment Data Lookup->Toyota->Alphard/Vellfire:H10 Series:MNH10W
Alignment Specs
Parameter
MIN spec
Standard spec
MAX spec
Front Total Toe
-0.17
0.17
FL Toe
-0.09
0.09
FR Toe
-0.09
0.09
FL Camber
-1.42
0.08
FR Camber
-1.42
0.08
Rear Total Toe
-0.25
0.25
RL Toe
-0.13
0.13
RR Toe
-0.13
0.13
RL Camber
-2
-1
RR Camber
-2
-1
Left Caster
1.67
3.17
Right Caster
1.67
3.17
Left SAI
N/A
N/A
Right SAI
0
0
There are significant differences, so if anyone relied on the earlier figures for alignment, can I suggest you check them again?
Regards,
Pcous
Hi all,
Correction - I've been given yet another set of wheel alignment figures for 2002-07 Alphard, which are different from those I posted earlier- these came from our wheel alignment specialist, who searched Japanese data. They're a more extensive set of figures, but for some values the tolerance range is narrower than the figures above:
Toyota->Alphard H10 Series:MNH10W
Wheel Alignment Specification
Parameter
Minimum
      Maximum
Front Total Toe
-0.10
+0.10
FL Toe
-0.05
+0.05
FR Toe
-0.05
+0.05
FL Camber
-1.25
+0.05
FR Camber
-1.25
+0.05
FL Caster
+1.40
+3.10
FR Caster
+1.40
+3.10
FL SAI
+10.05
+11.35
FR SAI
+10.05
+11.35
FL Included Angle
FR Included Angle
Front Cross Camber
+8.40
+8.40
-0.45
+11.40
+11.40
+0.45
Front Cross Caster
-0.45
+0.45
Rear Total Toe
-0.15
+0.15
RL Toe
-0.08
+0.08
RR Toe
-0.08
+0.08
RL Camber
-2.0
-1.0
RR Camber
-2.0
-1.0
Regards,
pcous
