I am looking at a gearbox strainer for my 2.4 2006 Alphard two wheel drive, according to the Toyota parts list the part number is 35330-06010 BluePrint number ADT32145 which according to their list fits a Toyota Camry 2000-2006. Is this the part ?
I just took a look at the epc data (for the model which I THINK you have).
I believe the part number is
15014-28020
Please do not use this number without checking it thoroughly.
Are you aware of the epc data ?
Yes my number came from the Epic Toyota Parts list. Where about did you get that number? Is it for the kit or strainer?
Edited by Ayrshire Man
Hi just checked that’s not the gearbox oil strainer but the engine strainer attached to the oil pump in the engine. So yes my part number must be correct.
Hi. I got it from the Toyota Alphard EPC.
I'll check for the gearbox.
As I have said that part number is for the oil pump strainer not gearbox. The only reason for checking is in the part number list on the forum there is listed a number for the strainer 35330-28010. Which I believe is for the early 2002 Alphard.
Hi, I checked the gearbox drawings and you appear to be correct. Sorry for my mistake.
The part looks like a small oil tank !
Goo Luck.
If you go to the EPC, you can chose the model year, ie. 2002 to 2005, or 2005 to 2008.
I have sorted it thanks.
