Replacement bulbs
Hi all. Can anybody recommend what bulbs and size I can use in the headlights and side light's instead of the original ones. LED preferred as they look more up to date and are brighter than originals.πŸ€”πŸ€”
Β
Hi Ian,
Β
I await everyone's replies as I need a couple of side light bulbs.
I did getΒ  part number of the EPC data but haven't ordered any yet.
About Β£8 each !!
Hi Rojie, just had my replacement bulbs. Side(standard led) and dipped see pictures. Looks fab,super bright. Any reputable motor factor will have them.😎😎
Β
Hi Ian,
Β
Thanks for this. I have blue sidelights, which I don't really care for, and one has blown.
I am told they are easy to fit. Do you agree ?
Β
I'll look into the options at Hid4U.
Yes, a little fidley but easy. I used ice white sidelights and matched them up with the dipped headlight. Got DRL's going on after Xmas.πŸ₯³πŸ₯³
Β
I already have a two small rows of blue DRLs fitted low in the grill.
They do work, my wife says so, but no idea where the switch is yet.
Β
So many things to discover, and enjoy.
They should light up when your car starts up. There should not be a switch if they are wired in correctly.
Β
Just checked. They do. Thanks for preventing wasting my time how to switch them off.
Β
Are they H13 sides or headlights ?
22 hours ago, nov said:
Β
Hi Nov, Thanks,
Β
But are you sure ?
I typed in the link, then 2006 Alphard and the page said they would not fit.
DR4/DS4 dipped headlight, T10 side light's. T10 interior bulbs. 2.4s 2008. Good luck 😎
Hi Ian, Nov
Β
I needed to go to Halfords today, so I thought I would check out the side lights.
Β
Very interesting.
Β
I took a guess at the type I needed, and got it wrong.
What I bought were not T10, but no big deal; they were quite cheap. W501 I think. 5W, Blue in colour but emitting 3500k white light !
Β
However, what I did notice that most led lights on sale were (fairly) clearly marked for OFF ROAD use only !
Β
I assume anyone fitting the 35w or even 60w LEDS as side lights may fail the MOT.
Β
I just checked your threads and links. Thanks.
Β
I should have bought W5W. No matter, no disaster.
Β
Thanks to both for your help.
Β
Β
On 12/25/2021 at 12:29 PM, nov said:
Β
Hi Nov,
Β
How were these sidelights.Β
They don't appear "error free".
Are you getting any flashing or canbus errors with them ?
1 hour ago, Rojie said:
Β
Hi Nov,
Β
Β
Β
So far so good, no flashing or any errors.
Β
Β
Β
Hi Nov,
Β
Were these OK.
Mine didn't fit.
Did you need to modify the lamp socket or force the leds into it ?
The black part has a shoulder that prevented me from pushing the new unit into the socket.
Β
The supplier has given the option of some replacements, but so many to choose from !
Β
I was able to test the supply to the wiring, which is OK.
16 hours ago, Rojie said:
Β
Hi Nov,
Β
Were these OK.
Mine didn't fit.
Β
Β
Β
Mine don't go fully in as well but are secure enought to not fell out
19 minutes ago, nov said:
Β
Thanks Nov, I appreciate your help.
Β
I have chosen not to use mine. If one fails out into the light unit I'll never get it out again !
I bought some from Halfords which fit fine, but are too dim.
Β
Oh what fun ..
Β
Β
Oh what fun ..
These ones are snug, fully encapulated too, so wont corrode, I have used these in an older Regius and in my Alphard, I have these bulbs in the front side lights, rear sidelights, numberplate lights and all my internal lights except the boot light, which is a different socket type.
Pure white light and brighter than originals - I used a different type of led previously, they suffered from corrosion and started flickering and dimming after a couple of months, these ones seem to be doing well.
Β
https://www.ebay.co.uk/itm/382904669684
Β
The price is for 10 bulbs, so I bought 2 sets and did whole car in one go (2nd Gen Alphard)
Edited by Chris.ac
11 hours ago, Chris.ac said:
These ones are snug, fully encapsulated too, so wont corrode, I have used these in an older Regius and in my Alphard, I have these bulbs in the front side lights, rear sidelights, numberplate lights and all my internal lights except the boot light, which is a different socket type.
Β
Β
Hi Chris,
Β
Thanks for this.
I am being sent some replacements, hopefully they will fit 'snugly'
I also bought a different type, cylindrical, from another vendor.
Β
If all that fails, I'll go with these. Thanks again.
Β
ps I bought some tiny rear reflectors. Will advise when I receive them !
Β
Β
