starider Posted January 5, 2022 Posted January 5, 2022 Hi, thought I would start a new thread on fitting Heavy Duty Rear Springs to my 2007 Alphard, which would follow on from my recent posts. As I said in my last post, I had tried to change both springs, but even with the correct spring compressors and 4 post lift, I couldn't compress the springs enough to remove them. I decided to book into my friendly garage who do our MOT Tests and major work if needed. I won't describe how they were changed[1hour],as my advice is leave this job to the professionals. There is always the danger that if I describe the method, someone may try to do it for themselves, get it wrong and I could be in trouble. What I will say is, that the problem was the difficulty in swinging the axle beam down enough to get the old springs out and the new ones in. Two problems prevented this,one was the ABS sensors which needed to be disconnected and the flexible brake pipes/hoses which also needed to be disconnected. I took two mechanics to then pull the axle beam down enough to remove the old and push in the new. The Alphard now stands as it should and the bonus is that the new stronger springs have reduced the roll on cornering to some extent and towing our box van means that being able to have a correct trailer nose weight, will make towing more stable.[All for £62! bargain! with no hassle].
Rojie Posted January 6, 2022 Posted January 6, 2022 On 1/5/2022 at 9:06 PM, starider said: Hi, thought I would start a new thread on fitting Heavy Duty Rear Springs to my 2007 Alphard, which would follow on from my recent posts. As I said in my last post, I had tried to change both springs, but even with the correct spring compressors and 4 post lift, I couldn't compress the springs enough to remove them. I decided to book into my friendly garage who do our MOT Tests and major work if needed. I won't describe how they were changed[1hour],as my advice is leave this job to the professionals. There is always the danger that if I describe the method, someone may try to do it for themselves, get it wrong and I could be in trouble. What I will say is, that the problem was the difficulty in swinging the axle beam down enough to get the old springs out and the new ones in. Two problems prevented this, one was the ABS sensors which needed to be disconnected and the flexible brake pipes/hoses which also needed to be disconnected. It took two mechanics to then pull the axle beam down enough to remove the old and push in the new. The Alphard now stands as it should and the bonus is that the new stronger springs have reduced the roll on cornering to some extent and towing our box van means that being able to have a correct trailer nose weight, will make towing more stable.[All for £62! bargain! with no hassle]. Expand Good morning, Nice to have a happy ending. I would also caution members on changing springs themselves; putting themselves in harm's way. If anything goes wrong, a spring doesn't locate properly in the spring compressor (or moves during compression), or, as in my case (many years ago), a spring compressor fails under compression; a very dangerous situation can occur without notice. If an Alphard is 2 tonnes, each compressor is supporting 500kg minimum. If the tension is released instantly, a lot of damage can occur when that spring hits anything, you included. As Starider says, £62 is a bargain, and much safer than risking yourself. I doubt you can purchase a sturdy compressors for that price !
starider Posted January 6, 2022 Author Posted January 6, 2022 Hi, I actually have 4 sets of spring compressors of varying strengths and sizes, but were still very aware of the dangers. I watched the process from a safe distance and because of the amount of movement they were able to get,the springs were easily gently levered out. The new springs although a lot stronger, with a mechanic heaving down on the suspended wheel and a liberal coating of silicon on the seatings,plus a little force, the springs popped into place, once in their seats each one was able to be turned into their correct position. The profile of the seatings is quite deep and it was these that caused some of the problems. Also there is little room to to attach compressors evenly. I totally agree with you,I definately wouldn't advise anyone to try to do it DIY. Talking to the workshop manager, he re- counted many horror stories of springs flying round workshops and the damage caused. As I have said before I, in recent years changed rear springs on my Suzuki Vitara very easily and quickly, but the springs were shorter and the rear suspension movement was a lot less. I would suggest you find a small well recommened independant garage and call in for a quote. We are lucky,we have an excellent relationship with our garage and the Manager is of the same generation as myself and we spend a lot of time talking about classic cars and tractors when I go in for MOT Tests or for work to be done! Hope what Rojie and I have said helps.
ThuMentaliss Posted January 6, 2022 Posted January 6, 2022 How on earth did you manage to find a garage workshop that charged you £62.0 ? The average garage rates here in the south of England are now £75.00 + and you indicated two mechanics were involved in the work !😦
Rojie Posted January 6, 2022 Posted January 6, 2022 On 1/6/2022 at 11:52 AM, ThuMentaliss said: How on earth did you manage to find a garage workshop that charged you £62.0 ? The average garage rates here in the south of England are now £75.00 + and you indicated two mechanics were involved in the work !😦 Expand Perhaps one of the benefits of living in a rural part of the country. I pay £60/hr for my Fords, and £70/hr for my Jaguar specialist at different local garages.
starider Posted January 6, 2022 Author Posted January 6, 2022 (edited) Yep, living "down yer in dear ole Devon" has it's advantages, but many disadvantages, we only have 3 buses a week, one to Barnstaple,one to Holsworthy and one to Tavistock and if you miss any of these it's a taxi fare home! To get anywhere is by car[or tractor], and any real shopping is at least a 20mile round trip away.One of the mechanics was only involved for about 10mins, and I do know the staff really well. Edited January 6, 2022 by starider
ThuMentaliss Posted January 8, 2022 Posted January 8, 2022 On 1/6/2022 at 11:38 PM, starider said: Yep, living "down yer in dear ole Devon" has it's advantages, but many disadvantages, we only have 3 buses a week, one to Barnstaple,one to Holsworthy and one to Tavistock and if you miss any of these it's a taxi fare home! To get anywhere is by car[or tractor], and any real shopping is at least a 20mile round trip away.One of the mechanics was only involved for about 10mins, and I do know the staff really well. Expand Great, perhaps I should drive down to Devon from Brighton and get my work done cheaper, here a two rear spring replacement approx' 2.0 hrs work plus equipment to allow radius achieved to allow axle /spring beam clearance could cost £200 +
starider Posted January 8, 2022 Author Posted January 8, 2022 (edited) Blimey!! Seems awfully expensive to me, at their prices £100 per hour!! wow.If,as they should, be able to do the job in 1hour that's £100 extra profit. Perhaps they didn't want the job. What is the equipment they use other than a lift and spring compressors, I've never ever been billed for equipment! Edited January 8, 2022 by starider
