Hi guys,
As the title says,,,anyone know if it's possible to dim the speedo/rev counter etc. lights?...I find them a bit bright at night.
You can adjust the brightness with the speedo knob
toyota_alphard__354367537f.jpg.0cfda35c7689bdf54f7c3ac15a501c80.jpgDepends what model you have. Mine is on the dash just behind the indicator stalk. I have a 2nd generation. The switch that has the clock with up/down to dim the dash. ANH20W.🐲😎
Edited by Ian24
Added info.
what gen alphard?
On the 20series, I know that you can set via the buttons mentioned above, there is also setting in techstream to set the amount of dimming at night relative to the day setting.
Β
I'm on a 10 series I think (second half 2005)...looks nothing like the image above.
I'll have a go at twiddling my knob (ooer missus) and see if it does the trick.
Thanks guys!
It works! Thank you.
