Hi all,
Just bought a 2007 Alphard, just waiting on the registration so i can buy plates for it. I was wondering if anyone can assist in changing the audio/gps to english if possible?
Any advice really appreciated! 😁
Hi, not possible sorry. I've not found anyone that's able to do that. Only way is to have it completely changed.🐲😎
Try Ben Hau. He does a lot with head units. He is on the club forum.
Thanks for the advice @Ian24
Any updates on this?
any work around to have at least Bluetooth? 3.5mm audio input?
can‘t be bothered putting in too much money to replace it
I ended up buying a pioneer head unit kit had all the bit and pieces but was pretty much £300, fitted it myself. But no the head unit i had as stock was japanese only with no bluetooth or aux.
I don't know for sure, but your unit probably supports Bluetooth for phone.
Check Eightseaterbloc.com
And some Alphies have a VTR input in the rear of the front centre (between the seats) console;; that should take an audio input.
If you want cheap, you can always go the route of a FM transmitter/bluetooth adaptor like this:
https://www.aliexpress.com/item/1005002877156752.html
Allows you to connect your devices via BT to it, then connect it via FM, adds usb/sdcard storage and has its own little control buttons, so no fiddling with your phone.
Well said, i used one similar and its a solid option especially as the radio band is totally void of stations.
