Hi guys,
Tried to install a Panasonic JDM multimedia headunit and stupidly plugged in one of the plugs from the climate control to the back of the radio. That caused the following issues:
- climate control panel including sonar and clock is completely dead
- central door locking is not working when remote buttons are pressed or door key turned. However, it works when lock/unlock button on drivers door is pressed
- power sliding doors are completely dead
Any ideas what happened and how to resolve the above issues?
Thanks is advance.
M.
You have definitely blown a fuse there are 4 fuse boxes on the alphard your going to have to check all your fuses if you have a English owners handbook it will tell your fuse locations I hope you get it sorted .
All sorted. Found 2 blown fuses. D.C.C and A/C. Thanks :)
