Hello, i hope someone can offer some help. i have a 2003 Alphard conversion form Direct Campers. I have had it since 2020 but no managed to use it as much as i would like. We last went away in August last year and then moved house and got married so this coming weekend is the first time we will be using it as a 'camper'. today i have cleaned out the inside and tested everything is in working order. It is fitted with an internal LPG tank with a propex system. I turned it on and got the green lights which are showing as full (i filled it before our trip last year so it should be full). anyway on turning on there is no sound, usually you can hear a click as the gas is turned on. So lights on but no gas coming out of the hob, heater or BBQ feed at the rear. I have emailed Direct campers with no reply as yet so thought i would put this out here too as i only have 5 days to get this fixed before we go away.
Thanking you in advance 🙂
Just to update anyone that's interested. it turns out the valve was stuck. I have spoken to Jay at propex who is incredibly helpful and after a couple of fault findings i was advised to remove the plunger which was obviously stuck. Just waiting for replacement parts now.
That's handy to know. Thanks for sharing.
Hi Tony10,
I'm glad you've got this sorted. Just as a precaution, it's worth noting that campervan conversions typically have mains electricity, gas and water, all in a relatively small space, and it's worth having an annual habitation check to ensure there are no problems/leaks, ventilation is OK, smoke/CO alarms are functional etc. Our insurers also stipulate that we have a fire extinguisher handy....  I guess some people may be able to do habitation checks themselves, but for peace of mind we've had our annual check done by our local garage/campervan hirer .
Regards,
pcous
53 minutes ago, pcous said:
Hi Tony10,
Regards,
pcous
Hi pcous,
What was the approximate cost of your Habitation check.
Were you provided with a Certificate ?
5 hours ago, Rojie said:
Hi pcous,
Hi Rojie,
Our local guy charges £75 plus vat (without drain-down) and provides a checkbox certificate, ticking each item. He's thorough - for instance last year he recorded there were no batteries in the CO/smoke detectors (I'd taken them out over winter to avoid discharging when we weren't using the van and forgot to pop them back in again before I took it in for the check!). I've attached a list of what's covered - some of the underbody checks obviously don't apply to an Alphard conversion, e.g. body-chassis/cab-body mountings, corner steadies/steps, al-ko, also toilet, locker etc, but it's a reassuring check, especially for mains electrics and gas.
Regards,
pcous
Motorhome Habitation Annual Service Schedule.docx
Hi Rojie,
Ah..... so that attachment didn't work - here's the list:
UNDERBODY
Body to chassis mountings - check security
Cab to body junction - check
Underbody tanks & auxiliaries - check
Spare wheel retainer - check operation & lubricate
Corner steadies & folding steps (where applicable) - Check operation & lubricate
Chassis - lubricate axel tube (AL-KO) & Inspect non-original suspension components
12V ELECTRICS
12n & 12 plugs/cables (where applicable) - Check condition & test
Road lights & reflectors - check condition & operation
Fridge - check operation
Interior lighting & equipment - check operation
Habitation battery (where fitted) - Check condition, security, electrolyte level & lubricate terminals
Wiring, earth's & fuses - inspect condition & correct fuse ratings
Awning light & outside pump socket - check condition & operation
Fan maste – test
VENTILATION
Ventilation openings - check for obstructions & free flow of air
Adjustable ventilators - check for function
Roof lights - check to ensure free of obstruction
GAS (FRIDGE NOT SERVICED UNLESS REQUESTED)
Regulator - check performance
Carry out gas leak test
Appliances (including water heater, cooker, heating & fridge) - check operation
Pipe work - check condition & replace flexible hose & clips when necessary
Flame failure device - check operation
Cylinder - check security
Gas dispersal holes - check for blockage
MAINS ELECTRICS
Inlet plug, hook up cable (when available) earth bonding & RCD operation - check
Outlets & permanent connections - carry out visual & functional check
WATER SYSTEM
Water pump, pressure switch & heater - check operation & clean grit filter
Taps, micro switch, valves, pipes & tank (If fitted) - check condition & operation
Water filter & housing - check for leaks & replace filter if necessary
Waste system - check for leaks
Toilet - check seats, flush & blade operation
FIRE SAFETY
DIY additions - check operation & safety
Security & smoke alarms - check operation
Extinguisher (if fitted) - Check correct type fitted & expiry date
Fire blanket (if fitted) - check location & fixing
BODYWORK
Body panels - check & report on any damage & sealant condition
Door locks & hinges - check operation & lubricate
Body attachments - check security (including ladders, cycle racks, lockers, aerials, satellite dishes etc)
Floor - check for delamination
Cab seat - check operation (swivel type or bed configuration only)
Furniture - check condition & operation (incl. hinges, stays etc)
Windows seals & blinds - check operation & condition
Rising roofs - check operation (where applicable)
23 minutes ago, pcous said:
Hi Rojie,
UNDERBODY
12V ELECTRICS
Fan maste – test
VENTILATION
MAINS ELECTRICS
WATER SYSTEM
FIRE SAFETY
BODYWORK
Hi pcous,
Thanks for your answer.
It was a general enquiry intended for the informational benefit of all our members.
Very thorough, and not an unreasonable price imho.
Most Caravan suppliers will also be able to provide a Habitation Check service.
Thanks again
