Hi out there is there any other way to access the passenger fuse box I have taken out the glove box and piece of trim with the flare in but I still need to be a contortionist to even see the fuses I have a large piece of wiring loom just under it which restricts the assess even more and I can't move it what a place to put it any ideas would be helpful
As you may have seen in my previous post, once I had located the fuse box the problems were just as you describe.As I stated the fuse remover supplied is totally useless and long nose pliers were the only option. There is a small problem with the fuses being slightly smaller than the normal mini fuses available. If you go to my previous post I located the correct fuse size and listed the Ebay item number. It's OK, the stiff neck soon goes!!
Thanks for you help all sorted now just wondering who had the bright idea of putting the fuse box there.
