Rear video screen operation
The original toyota unit with mini cd and cd/dvd player, rear drop down screen. Sorry don't know the model number. 2005 3 litre
We would also like to know how to download songs onto the hard drive
53 minutes ago, Dave Firth said:
Thanks Rojie.
A photo of the screen would help.
Do you have the Home Theatre System ?
If you have an HDD drive, CDs will record automatically (until the drive is full).
Can you play HDD tracks that you have not loaded ?
Existing tracks can be deleted.
Try eightseaterblog.com.
There is a very good narrative for a common headunit, and it's in English.
It provides comprehensive instructions on how to use that particular system.
It may be the same as yours. Take a look.
Hi Rosie, photo attached.
That link does not work for me I'm afraid.
Thanks again!
You have the system that is featured by eightseaterblog.com.
Did you check it out. You do have a HDD system.
Check it out; it's in English and an invaluable source of information.
If the HDD is full, eightseater explains how to clear some space, ie. delete material.
Hi Rojie as i said eightseaterblog.com does not reach a website, just an error message.
Thanks anyway!
Hi all ,just bought a vellfire 2008 ,still struggling with dropdown back monitor,  does not have any button to flip it down ,any idea what do I need to select to bring it down,HU picture attached,any pointers will be helpful
Thank you
Thank you
Is it too obvious to say "Button marked TV"?
Thank you
Press 1st button on top row of physical buttons.
Now on the screen, press the top middle icon.
Hi..I am having the same player and the CD will not feed in. Is mine broken or is there a way of getting it in? Any help?
Do you mean the front screen won't tilt to allow you to insert disc, or that you can't get the slot to take a disc?
Its there a disc already inserted that is jammed?
