Hfgjgjhlhfdhfhdfhfdhdf Posted May 5, 2022 Posted May 5, 2022 Hi all, possibly stupid question but is there any way to open the tailgate from inside the vehicle (1st gen Alphard, non-motorised tailgate). If not, is it the kind of thing that an independent garage might be able to cobble together a solution for?
Rojie Posted May 5, 2022 Posted May 5, 2022 2 hours ago, Hfgjgjhlhfdhfhdfhfdhdf said: Hi all, possibly stupid question but is there any way to open the tailgate from inside the vehicle (1st gen Alphard, non-motorised tailgate). If not, is it the kind of thing that an independent garage might be able to cobble together a solution for? Hi Mr Secretive, Welcome to the Forum. Try Cuttothechase on Youtube. Or Ldrego on here. I believe he did a video on this problem. It involves disconnecting the main battery.
Chris.ac Posted May 6, 2022 Posted May 6, 2022 if you mean a permanant solution so you can always open from inside, i.e. you are using as a camper and want to get out the back, then yes, it would involve cutting a small aperture in the lower panel and perhaps spot welding a small handle to the manual release latch. Much simpler on the 2nd gen, as there already exists a removable panel to actuate the mechanism with a screwdriver.
Rojie Posted May 6, 2022 Posted May 6, 2022 1 hour ago, Chris.ac said: if you mean a permanant solution so you can always open from inside, i.e. you are using as a camper and want to get out the back, then yes, it would involve cutting a small aperture in the lower panel and perhaps spot welding a small handle to the manual release latch. Much simpler on the 2nd gen, as there already exists a removable panel to actuate the mechanism with a screwdriver. I have discussed this approach with my convertor, creating a small access opening. As of today we have not progressed if. Fortunately, my rear conversion does not have a fridge in the usual place but does have a cupboard with access from inside and outside BUT. The rear cupboard doors open outwards, impossible if the tail gate is closed !! Possible if I create access through them, or remove them. NO. Another solution needed.
Hfgjgjhlhfdhfhdfhfdhdf Posted May 8, 2022 Author Posted May 8, 2022 Thanks for your replies Rojie and Chris. Chris, you hit the nail on the head with what I’m trying to accomplish, and your suggestion makes sense. Rojie, I quite like that moniker so henceforth I will be using it here. cheers, Mr Mysterious
Chris.ac Posted May 8, 2022 Posted May 8, 2022 seems like the russian host of the gen 1 alphard maintenance manual has had their site cutoff Looks like back to the search engines to find a copy, it would have had the info you needed, too.
Rojie Posted May 8, 2022 Posted May 8, 2022 23 minutes ago, Chris.ac said: seems like the russian host of the gen 1 alphard maintenance manual has had their site cutoff Looks like back to the search engines to find a copy, it would have had the info you needed, too. Oh what a shame. After all that hard work you did ! Putin. Could be there still, but no access from The Allied countries !
Register a new accountSign in
