This thread is intended for information only.
It is not intended for discussion.
The list was supplied by pcous regarding work done on his Alphard.
Motorhome Habitation Annual Service Schedule
UNDERBODY
Body to chassis mountings - check security
Cab to body junction - check
Underbody tanks & auxiliaries - check
Spare wheel retainer - check operation & lubricate
Corner steadies & folding steps (where applicable) - Check operation & lubricate
Chassis - lubricate axel tube (AL-KO) & Inspect non-original suspension components
12V ELECTRICS
12n & 12 plugs/cables (where applicable) - Check condition & test
Road lights & reflectors - check condition & operation
Fridge - check operation
Interior lighting & equipment - check operation
Habitation battery (where fitted) - Check condition, security, electrolyte level & lubricate terminals
Wiring, earth's & fuses - inspect condition & correct fuse ratings
Awning light & outside pump socket - check condition & operation
Fan maste – test
VENTILATION
Ventilation openings - check for obstructions & free flow of air
Adjustable ventilators - check for function
Roof lights - check to ensure free of obstruction
GAS (FRIDGE NOT SERVICED UNLESS REQUESTED)
Regulator - check performance
Carry out gas leak test
Appliances (including water heater, cooker, heating & fridge) - check operation
Pipe work - check condition & replace flexible hose & clips when necessary
Flame failure device - check operation
Cylinder - check security
Gas dispersal holes - check for blockage
MAINS ELECTRICS
Inlet plug, hook up cable (when available) earth bonding & RCD operation - check
Outlets & permanent connections - carry out visual & functional check
WATER SYSTEM
Water pump, pressure switch & heater - check operation & clean grit filter
Taps, micro switch, valves, pipes & tank (If fitted) - check condition & operation
Water filter & housing - check for leaks & replace filter if necessary
Waste system - check for leaks
Toilet - check seats, flush & blade operation
FIRE SAFETY
DIY additions - check operation & safety
Security & smoke alarms - check operation
Extinguisher (if fitted) - Check correct type fitted & expiry date
Fire blanket (if fitted) - check location & fixing
BODYWORK
Body panels - check & report on any damage & sealant condition
Door locks & hinges - check operation & lubricate
Body attachments - check security (including ladders, cycle racks, lockers, aerials, satellite dishes etc)
Floor - check for delamination Cab seat - check operation (swivel type or bed configuration only)
Furniture - check condition & operation (incl. hinges, stays etc)
Windows seals & blinds - check operation & condition
Rising roofs - check operation (where applicable.
I respectfully submit this as an example only.
Thanks again to pcous for disclosing this list.
The cost ?
£75, plus VAT.
This topic is now closed to further replies.
