Can anyone tell me what this little push switch is for please?7518332A-BDC4-4A63-96D2-399C586B03BB.thumb.jpeg.ccb6b525443ef6d8ce09c105d390b1ef.jpeg
If not clear, it’s under the main central panel.
Hi again Oddie,
I have come across these reasons, so far, for extra switches.
One is for the rear fog lights, if added for the UK MOT; but the switch needs to be lit when activated.
Two, is to allow the radio to work when the ignition is switched off.
There is another,  if I can remember it !
Sometimes the original owners have added gizmos that get removed before export
Hopefully I'll add it tomorrow, if no one else does !
7 hours ago, Rojie said:
Hi again Oddie,
I really hope it’s the radio option! Rear fog is on another switch, I’ll have a bash with the radio later on!
Phaaah, not to get the radio on, gutted!
It may be the on/off switch fro the power source next to it....
Could be a handbrake bypass switch?
It may allow video to be played on screen whilst the vehicle is in motion.
Randomly the dvd plays when driving, which isn’t ideal for someone as easily distracted as me😆. We’ve tried pushing it on and off to see if anything changes, as yet no joy…..
55 minutes ago, OldWellhouse said:
Ejector seat
I did try that at the weekend with the wife, which I found funnier than her, not sure why…
stud things are to clip the curtain ties to..
The button near the power outlet is usually a way to send a handbrake signal to the headunit so that if thinks you are parked, and allows you to do things ordinarily blocked, such as adjust the bluetooth settings, display video on headunit.
Edited by Chris.ac
Thanks for that Chris, I’ll have a full play later if I can. Noticed that dvds play all the time so perhaps this is the wee button allowing that!
Doh!
cheers.
 Handbrake bypass. That's the one I couldn't remember.
14 minutes ago, Rojie said:
So your radio works with the footbrake applied ?
To be honest, I’ve never had the need to put the footbrake on yet! But dvds happily play when driving on both front and rear screens, will have a play at the weekend…
Front screen should not allow you to watch DVDs while driving,; listen yes, watch no.
So it does sound like a footbrake override that allows 12V to whatever is the correct pin !
2 minutes ago, Rojie said:
Front screen should not allow you to watch DVDs,; listen yes, watch no.
Will confirm at the weekend, sounds the most plausible so far!
I would agree that it is the handbrake override to allow the video in motion.  I have similar on my bus.
Will let you all know in a couple of days, must admit though, when I thought it might be a way to use the head unit without having to have the ignition on it made me warm inside, that’s going to be the next task!
So I can now confirm, whatever it’s for, it has nothing to do with the head unit 😂
