Any suggestion regarding pull/push clips holding side trim on front bumper (Alphard 2008 3.0). Mine is coming loose and clips need replacing. where to get? regards, Rod Parker Isle of Wight.
I noticed a couple of mine are missing on my rear wheel arch. Have you found the right ones yet? The range of clips available is vast.
Thanks All, I have made a note of RomaHome in Cowes and will be contacting them when thinks start getting worse. At present the panel is being held in by one bolt which I check for tightness regularly.
