auxilary belt replacement
Hi, does anyone have experience sourcing an auxilary belt for a 3.0 V6 (1MZ-FE). I've heard that it's the same as a Camry or Lexus.
Many thanks
Many thanks
Hi Gag,
You should be able to find the part number from Toyotaalphardepc.com
There is an ever growing list of spares on this Forum, whether it has your belt could be a different matter; hence the EPC.
With the part number you can order from Toyota Direct or some, but not all, Toyota dealers.
Good luck
Thank you Rojie. I'd used the search on here with no results & been phoning the importer all morning to no avail hence the post here. Finally got through to him & it's the same engine as the Lexus RX 300 4wd & that's what he uses for the auxillery belt & other parts.
