The fuel gauge and speedo intermittently work - is there any known issues or anything I can do to fix this?
Many thanks
I would get the speedo chip checked behind the speedo sounds like it's a bad connection some fitters use connectors on the wires when really they are supposed to be soldered .
Many thanks
Hello Kevin,
It’s always worth checking battery connections are nice and tight and the battery itself is in good order.
Low voltage can sometimes cause spurious faults.
