Ayrshire Man Posted August 20, 2022 Posted August 20, 2022 I have installed Apple Car Play via an adaptor unit and it works fine until I release the handbrake when it goes off. I presume this is so you can’t watch the front screen whilst driving. I have seen on the Mk2 there are 2 wires for the handbrake and speed sensor to disconnect, I presume it is the same for the 2006 Mk1 with the Toyota larger screen fitted. I have found wiring information for the Mk2 even information on the connectors at the rear of the head unit but nothing of use for the Mk1 Alphard. 1
Chris.ac Posted August 21, 2022 Posted August 21, 2022 (edited) They look like more standard toyota connectors, should be the 5 pin grey connector, as this is commonly used on older headunits. (marked 12 on your photo) Try this page: https://pinoutguide.com/Car-Stereo-Toyota-Lexus/Toyota_Estima2003_head_unit_03_pinout.shtml Edited August 21, 2022 by Chris.ac
Chris.ac Posted August 21, 2022 Posted August 21, 2022 If you have multimeter, you can confirm signal is going from a voltage, down to 0 volts when handbrake released, please let us know, so we can build on the knowledge 1
Ayrshire Man Posted August 21, 2022 Author Posted August 21, 2022 Yes you are correct, that is the connector, the wire colours No 1 blue with a yellow stripe No 3 red. I haven’t been out yet as the battery is on charge but it still works with the hand brake off
Chris.ac Posted August 21, 2022 Posted August 21, 2022 2 hours ago, Ayrshire Man said: Yes you are correct, that is the connector, the wire colours No 1 blue with a yellow stripe No 3 red. I haven’t been out yet as the battery is on charge but it still works with the hand brake off i think the pink stripped wire is reverse signal, too, if you need it.
Chris.ac Posted August 21, 2022 Posted August 21, 2022 2 is parking assist system 3 GPS antenna 6 Telemetric system (G-Book, Toyota assist) 7 not used on mine, not sure what this is 8 I think is external DVD/CD multichanger 13 is TV/DBT & antenna Somewhere in the other connectors, you'd have Aux in (which you have already discovered) Electronic Toll Collection system, speakers etc, rear screen connection etc
Register a new accountSign in
