Handbrake and speed sensor preventing Apple CarPlay Working Mk1 Alphard
I have installed Apple Car Play via an adaptor unit and it works fine until I release the handbrake when it goes off. I presume this is so you can’t watch the front screen whilst driving. I have seen on the Mk2 there are 2 wires for the handbrake and speed sensor to disconnect, I presume it is the same for the 2006 Mk1 with the Toyota larger screen fitted. I have found wiring information for the Mk2 even information on the connectors at the rear of the head unit but nothing of use for the Mk1 Alphard.
If you have multimeter, you can confirm signal is going from a voltage, down to 0 volts when handbrake released, please let us know, so we can build on the knowledge
Yes you are correct, that is the connector, the wire colours No 1 blue with a yellow stripe No 3 red. I haven’t been out yet as the battery is on charge but it still works with the hand brake off
i think the pink stripped wire is reverse signal, too, if you need it.
2 is parking assist system
3 GPS antenna
6 Telemetric system (G-Book, Toyota assist)
7 not used on mine, not sure what this is
8 I think is external DVD/CD multichanger
13 is TV/DBT & antenna
Somewhere in the other connectors, you'd have Aux in (which you have already discovered) Electronic Toll Collection system, speakers etc, rear screen connection etc
