ANH10 headlights unit update
Hi Guys,
my current headlights works 100% but the housing have minor micro cracks inside. I already polished them. I’m thinking to buying a set with better conditions to replace. Does the facelifted version ANH15 plug and play straight to my 2003?
Other than eBay. Could someone point me to another source?
thanks in advance.
I have purchased updates headlights unit and tail lights. Just waiting for them from Japan. Will update here after installing. Cheers
The ANH15 LED rear lights arrived today. The install was straight forward and I got to clean the insides. Confirmed fitment on the rears.
What do you guys think about them?
C325DE75-BB8B-4B69-ABA6-51A9D069C3C9.thumb.jpeg.24216c4d1a4c1e238c02e8051fbb75a8.jpeg787A3B49-606A-4DB8-8C44-39F3B1D5A3E8.thumb.jpeg.756206f80f02438049c99d8734b7014c.jpegDAF27D16-460E-42DC-A135-C4DE8AAF467D.thumb.jpeg.b461dd30795b73a7f6e9240ea920f86a.jpeg389AAC2B-CCA8-4BD2-916B-0775B4F40623.thumb.jpeg.8b8d54b717df1deffec0c3170abf617c.jpeg
Very nice!
Are they noticably brighter?
They reuse the oem reverse and signal bulb sockets. I will order replacement LED bulbs. They are overall brighter! Great fit!
  • 2 years later...
Plug and play? No need to mod? Nice.
Do anh15 projector headlights plug and play into a anh10? Thanks for any info
ANH10 is front-wheel drive and ANH15 is 4WD. That's the only difference.
It's not that ANH10 is pre-facelift and ANH15 is post-facelift. Both model codes were used pre- and post-facelift.
So you need to look for the correct variant pre or post facelift, but otherwise, ANH10 and ANH15 should be the same for something like this.
