How to open boot with dead battery?
Battery had died on my Velfire, took it out to charge but then boot got locked.
I can open other doors with key but other issue is that I have a bed loaded at the back, so can't access battery area from side doors. Really need to open the boot door somehow. Would be grateful for any advice.
I suppose you cannot access the lock panel cover, if bed in way?
Lock panel cover?
On 9/11/2022 at 10:15 PM, maq said:
Lock panel cover?
on the rear panel, there is a panel that is removed to access the manual override with a screwdriver
Hi Chris,
Thanks for this.
Does you answer apply to Gen 1 as well ?
4 minutes ago, Rojie said:
Hi Chris,
Thanks for this.
no, gen 1 is a single panel, and because it's held by two screws on lower rim is not possible to remove without damage, whilst door closed.
20 series has 4 removable panels to access the bulbs and lock
Regarding The Gen 1.
Cuttothechase on youtube has a fix for early Gen 1 machines.
Just remove the negative battery terminal, wait a couple of minutes, and reconnect battery.
Battery does need to fully functional. Boot lock should be reset.
I have not tried this myself. Fortunately, to date, I have not needed to.
let's be thankful is a Toyota, my friends Merc c class is always throwing fits and error messages, latest thing is the reverse cam has stopped functioning, and it has a motorized cover on it so will be probably the cost of a set of tyres to replace
