Has anyone had a problem with the sliding door siezing up? It was ok one minute then the next time I opened it the motor took it half way the ground to a halt. I tried to close it with power on but it stuck. With power off it was all I could do to get it shut. It is now virtually impossible to get open. Anyone else had the same? If so did you find a solution.
Many thanks
Many thanks
I suggest you charge your main battery, while you watch Cuttothechase on Youtube.
He has a video on how to deal with a troublesome / snapped sliding door cable.
It is probably something else; but no harm done.
Good luck
