headphone sockets not working
Hello ,
         i have a 2006 toyota alphard mzg and recently connected headphones to the relevant sockets behind the centre consul, but no sound is coming out when i play the dvd on the original head unit that came with the car,does anybody know if there is a button i need to press on head unit to get sound through headphones please thankyou martin.
3 hours ago, martin h said:
Hello ,
Hello Martin,
I am assuming you have the Home Theatre System ?
yes i do
Hi Martin
I don't have the Home Theatre System, and am wondering if you do !
Does the passenger seat have lots of electronic gizmos ? It should have.
If so, is the rest of the system working OK? All (12, I think) speakers ?
May I respectfully suggest you try eightseater,blog.com (or something very similar).
He provides wonderful insight into the HDD head unit you have
It may help you; hope so.
OK I will thankyou for your advice
Hi Martin.
This is the same set up as I have though mine's MZ V. 2005
It does appear to be the Theatre system in place( I can just see the speaker on the top of the dash), though I'm not sure which gadgets on passenger side Rojie is referring to?
Maybe he has seen some upgrades on his internet travels!
I confess, i've never tried my headphones and have now changed out the headunit to Kenwood so don't think they will work, but will have a check when i can.
42 minutes ago, Catweazle said:
Hi Martin.
I believe the Theatre System has amplifiers (and goodness knows what else) all installed under the passenger seat.
Some, or all, of that could be missing.
Are the buttons push buttons to on and off ?
My guess is the controls have been disconnected as the Japanese owner has removed some form of upgrades.
Sorry, I have no definitive solution.
Thankyou all for your advice if I managed to get it sorted I will add it to this forum in the hope it will help someone else,
Thanks again martin
Just a thought, have you tried it all with the rear screen down, and powered on with remote?
Have a look on the remote button and see if there is a mute button.
I haven't tried that catweazle I will give that a try and see what happens thanks everyone for your input
