Dashboard Warning Lights - engine and 4WD = no power
Just recently been getting a sporadic problem: Engine starts but dashboard warning lights are yellow for Engine and 4WD and I am unable to get any power. Come back 10 minutes later and all is fine. This keeps happening. Any ideas welcome.
Hello Trevor,
Nice to have a new member from so far away.
I hope some of our members are able to help you with some suggestions.
Good Luck.
Hi Trevor I am also getting the yellow engine signal on my v6  when I am on a second tank in a row  of GPL gas  BUT  if I stop the engine and go on petrol it does not come on again , so I am wondering if its a problem of engine heat or gas distribution problems ! so I hope its not dangerous for the moteur ! any  ideas guys and gals ?
Did you make any progress?
Turns out - faulty throttle unit. Thanks
Interesting.
I'm having similar symptoms. Mechanic is struggling.
How did you get this diagnosed?
