Hi im getting p0172 code fuel trim too rich can you tell me where is bank 1 and how i can fix this on a Toyota alphard 2005 2.4l thanks
Hello Steven,
10 hours ago, Picasso said:
Front lamba sensor top one at manifold
Thank you for your reply can you tell me what part number i need and were is best place to get 1 thanks
8 hours ago, Picasso said:
What's your reg no.
Sj05 naf mate
1 hour ago, Picasso said:
Hi oe part no. Is.   8946758090. Put into ebay about £55.00 picture attached showing location and circled in red
Brilliant thanks mate 👍👍
  • 2 years later...
Hi, I've also getting this code intermittently, I've changed the MAF and the upper and lower Lambda sensor.
Anymore ideas?
Anymore ideas?
Hello Michael,
Hi Michael did did you replace the upper lambda sensor with a aftermarket or genuine one reason asking is the upper one is a fuel ratio sensor not a lambda sensor
Manual shows the the sensors are the same part number. So bought two RIDEX parts.
