Might be a silly question but can anyone advise we’re to find the VIN on my alphard ?
Hi Frank,
Passenger side B pillar is where it is on mine .
It won't look like a European one.
It will begin with your model number (ANH) and the latter digits are your VIN number.
For example ANHW-10  0098765.
It should be on your auction certificate if you have one.
Hope this helps.
Thanks I was confused because everything I looked up said a 17 character vin but mine actually only has 12 I had to check the door pillar and the engine compartment
Yes Roger is right,   my 2008 Vellfire shows  ANH20 -8033602  on Export certificate.
