Ok, so i have seen some rumors around the net that fitting CC is as simple as buying the control online, and splicing in the black wire on the steering wheel. (without blowing your self into boot via the airbag of course.
Is this true, or is it a load of crud. I have the 2002 model 3.0l v6.
with everything the car has on it, Including lane guidance (doesnt work in uk as far as I know)  electric curtains, 100v AC inverter etc etc but they didnt have CC.
only easy on the facelift models as these had electronic throttle - I believe the 2002 has a cable throttle.
Someone else might clarify, or you could check you throttle housing and see if it is cable driven
Edited by Chris.ac
Where do the red and black wires go the pug in the steering wheel xlockspring has three empty plug holes???
Hi
I followed this you tube video today with a part from Amazon (CENPEK Cruise Control Switch 84632-34011 for Toyaot Carym Coaroll Highlander RAV4 Matrix Tundra Lesxu Yarsi Scion)
works perfectly on my 2006 plate 2.4
