Hi all was wondering if the v16n-r57c rear dvd screen can work with a uk stereo unit that as been fitted into my 2008 vellfire. Or will it only work on the Japan head unit that was fitted in van when was built ? Sorry I’m new to all this but would be great to get rear screen working if possible for kids and adults to watch. Thanks 🙏🏽 for any help.
Hello Mark,
Thank you hope someone could answer my question or had same problem etc 👍🏼
To get the uk head unit to work it needs 2 video outputs most radios have 1 video out put which the installer will plug in the reverse camera so ideally when buying a upgrade head unit buy one that hase 2 video out puts .
Ok will have to check the back of the head unit that been fitted to see. If not only one can you buy a connector to get two coming out?
Not to sure I know when I had my alphard head unit changed and had it fitted in a garage who specialises in fitting car audio they said that I would loose rear monitor due to one video output I guess if there was a adapter they would had done it .
Just found this on amazon so I will look at back of my head unit and see how many video outputs if one I might buy cable and just try it see if works 👍🏼
Hi
I'm having the exact same issue with my monitor. Did the cable work and fix the issue?.
Many thanks
Hello, Neil. I got a 2010 vellfire a few weeks ago, with the 18 speaker system and factory roof monitor, no 360 cameras.
This Tesla style unit was plug and play, made by navirider, from Ali Express 20240709_194956.thumb.jpg.31cfab711040b08a11afd2424fb83869.jpg
It came with a hdmi out socket. The retailer provided a small black box, that converted the digital hdmi to 2 analogue RCA's. I then connected a standard single RCA lead from this box upto the roof monitor. Retailer also provided a breakout lead, which plugged into the roof monitor, and the original connector then went into the other side of the lead. It had an RCA cable coming off it. I plugged my RCA extension into it and it all worked, initially mirrored the display, but with help from the retailer and his engineer on WhatsApp, found out there was a hdmi assistant built in. With this enabled, you can have a video coming out the back, whisky your satnav or whatever is showing up front
It was completely plug and play. Only one fly in the ointment: the rear camera won't work. I have another on its way. But, steering wheel controls work. Also, there is some canbus interface : a display pops up with which door/boot has opened, in reverse, despite the current blank picture (!) the parking sensors show up with proximity lines, and the steering guide lines are dynamic, so once I get a camera in, I won't have lost anything. I intend to do this with a wireless transmitter/receiver kit, as I did on my estima.
There are a few small issues : you can only drop the rear monitor with the remote. It's buttons are very limited, obvious, so volume, next/previous video, is about it. One of them goes from normal to wide 1, followed by wide 2. This button finally got the display on the monitor full screen.
  • Thanks 2
There's a wire/pin called vmtr, which i think might be the signal to open the screen when held at 12v.
I'm just speculating.
Nice one, Chris. Will have to explore when I have time
  • 5 months later...
Hi, Going to be an owner of a vellfire soon and like the look of your setup.. Any chance you got the model number of the head unit? I see they do a few.
Hi. Ok, so this was the link :
I just found this on AliExpress:
£464.76 | 12.1inch 256GB Tesla Screen Android 13 Car Radio For Toyota VELLFIRE Alphard H20 2008 - 2014 RHD GPS Multimedia Video Player HU
https://a.aliexpress.com/_EH1do1Q
HOWEVER, the seller had a long conversation with me after sale, asking for pics of the front AND back of the factory fit, age of car, model, etc, etc. He then said I needed a different one,  with a built in amp for the 18 speakers. My advice : talk to the seller via msgs about your requirements.
  • Thanks 1
  • 6 months later...
This is the same unit I have. I have the T600 and 18 speaker system and canbus unit.  I tried all the suggestions on this forum but could never get the roof monitor to mirror the head unit. I used the usb cvs video converter and wired it into the same as another member did with a different head unit by pinning it into the original block connector behind the original head unit. I think I had it working once with a black and white screen with the ms video app when I fresh installed the app. Then just a blank screen. I tested the signal from the usb to the front by plugging the cvs to the input in the middle rear console video audio input and the usb cvs works on the input app so I know it works the opposite direction. If you ever figure out how to get this working please let me know.
