access to reversing light
hi i have 2005 alphard with 2 reversing lights one is not working do you have to take the rear door panel off to access  thanks stewart
Hi, I changed a tail light bulb on my 2003 recently.
You might find these pictures useful for location of trim buttons, there are also 2 bolts in the handle & 2 small screws in the panel left & right just below the window (highlighted).
Also highlighted what I think will be the reversing lamps, they are probably glass wedge bulbs (W5W), the holders just twist out.
Cheers, Chris
Sorry, being reverse lamp bulbs they will be 16W not 5W (as in tail) ie W16W, but check what you take out before you buy.
Hi that's great thanks very much I'll give it a go
Hi you wouldn’t by any chance know where I can get the reverse bulb holders from?
  • 8 months later...
Cheers, Chris
Was your foglamp bulb there as well
Was your foglightbulb there as well
