Alloy nuts
Does any one know the size an where I could by black wheel nut to got with my alloys that I just bought please
Is these nuts for toyota alphard 2007 thanks
Im not sure of your issue? if you have fitted or purchased new non-standard road wheels then you need to go back to your supplier as they should have supplied the wheel nuts within the purchase. However, if you want just one wheel nut you might have set yourself a problem,   best bet is to visit your friendly tyre fitter who maybe able to assist you......HALFORDS have always been helpful to me😎
I can tell you the standard nut size for standard studs.
But since you have changed your wheels they may not be suitable; and that could be dangerous.
Some details about the wheels would be helpful !
My wheel size is 5 x 114.3 I am using the original silver nuts just now but would like black ones to go with my alloys thanks for ur help much appreciated
5x114.3 is the bolt pattern, not wheel size, are you using the stock alloys, or do you have aftermarket alloys fitted?
