I have an engine management light on, on my 2005 3.0 v6 alphard.
I've checked the code and it's showing P0155 bank2 sensor 1 , 02 error.
I've been advised there are 4 sensors. Should they all be swapped out at once?
Does anybody have a part number.
And a reliable supplier?
Hi Craig I have had this code myself it also points to airflow sensor there are 2 o2 sensors of front and 2 rear rear ones rarely fail front one easy to do as just under the bonnet rear one you need it to be on a ramp I solved my problem bottle of a good cat cleaner in a quarter tank of fuel and a good blast foot down worth a shot doing that first £20 for a bottle cat cleaner since doing mine last summer never had a problem and I put a bottle in now once every 6 weeks if you still want to get the 02 sensors google autojapspares
Edited by Picasso
Spelling
Get to about 40 mph then I have had vsc trc off and engine management lamps on with high fuel consumption have changed all 4 sensors with aftermarket ones problem still here should try the cat cleaning thing any help welcome
update just stuck a bottle of cataclean in it ran it up fault cleared will keep an eye on it and report
It's worth giving it a blast after bottle cat cleaner doing small journeys is no good so so once a month put a bottle cat cleaner in and give it a good run
