Good evening,
I've just purchased a 2009 Vellfire 2.4, and would like to get some locking wheel bolts for it; does anyone know which size I need to get. or any particular make/supplier?
Thanks in advance
Phil
I picked up a used set for Toyota Yaris 2004 model year on eBay for about £20 they fit.  Same bolt pattern on lots of Toyotas.
13 hours ago, Phil Tivney said:
Good evening,
Thanks in advance
Phil
Hello Phil,
Depends on which wheels you have fitted.
Are they original OEM ?
I have a different model than you.
When I bought some I needed to be aware that the NUTS, not bolts, need a flat washer; not a conical one.
I purchased mine from McGuard.
There were fiddly to fit, but once you understand the quirk the flat washer provides they can be fitted quite quickly.
I'll check what I bought and advise.
Thanks guys; my wheels are the original ones.
Your help is much appreciated.
McGard 21156SU Lock Nuts for Toyota Alphard [Mk1] 02-08 on Original Wheels
These are for my MODEL and will not necessarily fit yours correctly.
I suggest you contact McGard. Disclaimer, there are other brands available !
