Have found the apparent speedo fault via the forum. Could anybody please tell me where to access the correct wiring.
Thank you.
Open links in chrome browser, use built in translate Japanese to English.
1st link describes meters and layout, warning lamps, how each system works etc.
2nd link is pdf wiring, you been use an online pdf translate tool if you want to see the labels in English.
Good luck.
Just now, WAYNE Garner said:
Thanks Chris, but unable to trace the actual place the wiring is located !
Ie behind dash or under dash ??
What specific wiring are you looking for? I dont own a 10series, so im not fully motivated to translate all the japanese from the online site - it does contain all the routing diagrams to indicate where the wiring is, as well as what it connects to.
An alternative is to download a copy of the russian alphard/previa workshop manual, unfortunately, its in russian.
search for "1067-TOYOTA-ALPHARD-2002-2008-ESTIMA-(2000-2006)-workshop-manual-download"
