I am looking for someone in the Exeter(ish) area who can fit a roof aerial to give my DAB+ a better chance. I have a stick-on screen variety at the moment and DAB isn't much cop in these 'ere parts.
Also, I'm not convinced about the effectiveness of the FM aerial in the rear windows - I often lose signal momentarily or get interference. So I'm happy to try a roof aerial for both formats.
Apologies is this is an incorrect post. Happy to be redirected / have hand slapped.
Hello Graeme,
When you speak of FM reception, and the window aerials, are you using an OEM Head Unit ?
If so, are you aware that the OEM units will only receive Radio 2 on FM (analogue) without a band expander ?
For most DAB frequencies you should install a 'FIN' type aerial fitted to the roof (rearmost) of the vehicle where there is less vehicle electrical interference but be prepared for a shock as the FIN'S are quite expensive + fitting... I have fitted several over the last few years, and they do sort out the Dab Radio reception issue and can help head units that contain Sat Nav IT intelligence.
It's a Sony replacement unit. I'd read on here that a short stalk installed above the front interior light works well.
4 hours ago, Rojie said:
Hello Graeme,
Thanks for your response, Roger. Yes, the band expander drove me up the wall (not literally!) so got a Sony unit which has not been the foolproof solution I had hoped.
Thank you for your response, Larry. So, next time I visit my daughter in Worthing ......
There is a chap called Steve who does the DAB installations at Topsham car sales (where we bought our Alphie from). He is ever so helpful and I have no doubt he will be able to sort it for you.
Thanks for that helpful tip, Angela
