Hi just purchased alfard 2007 2.4. the foot brake pedal reserve is very low resulting in a near failure to stop it has an mot and just been serviced prior to my purchase it comes with a 6 month guarantee any ideas? Derek B
Hello Derek,
Take it back to your seller.
Assuming it was a business sale, they should fix it under warranty.
Was  the seller the garage that 'service' it ?
Presumably, you have checked the fluid level.
Does the braking improve if you repeatedly 'pump' the brake pedal ?
Hi Rojie thanks for the reply I am not sure if the seller serviced the vehicle they said it had been serviced and brake pads checked The brake pedal does pump up slightly then goes down again The seller is quite far away so may have to get it checked near to me Thanks again Derek B
Hi Derek,
Some of the better dealers will renew the rear bushes before sale.
I believe this involves lowering the rear axle.
More learned members will comment, I hope; but I think the rear brakes need bleeding afterwards.
Sorry to be so cynical, checking brake pads is not the same as replacing them if needed !
If this situation has just occurred it seems strange to happen so soon after an MOT pass.
Hi Rojie thanks for your replies regarding my brakes on the alphard good news my local garage checked my brakes and the fronts were 80%worn so replaced front discs and pads changed brake fluid all ok the dealer paid the bill. Also I need a rear seat belt extender not the same size buckle as front  Thanks for your help Derek B
Hi Derek,
It is refreshing to know that some dealers support their responsibilities as yours clearly has done.
