Any advice on purchasing new Cv drive for 2003 Alphard v
Driver side although I thought they were compattable with either side
No they are handed do you want complete driveshaft or just cv joint normally if its just outer joint you just replace that will do passenger or drivers side but if its inner joint will be handed what's your reg no. Will have a look what's available for you and give you part no.s
Edited by Picasso
You have inner joint which is part no. 4303028011 then you have outer joint part no. 4347029626 both part no.s would create you a complete offside drive shaft if you put both no.s in ebay you will find the parts you require
