FOB not opening sliding doors or boot.
I have searched and read a few forum posts.
I reprogrammed the windows (except one).
could this be a battery issue? if so should i expect 14v or more on the battery without the engine started?
or do I need to programme the fob?
Thanks all
Edited by fiaraz
Thanks all
Hi Again
the doors on mine need a second press on unlock before I can open sliding doors. do a second unlock press and you should hear lock disengage, boot should do same. but the boot on mine is manual opening so once second unlock pressed I have to use unlock lever above number plate
Edited by atlanticcobra2023
typo error
9 hours ago, atlanticcobra2023 said:
Hi Again
ok bit embarrassing, theres a button on the dash board that switches the sliding doors off!  Thanks for all the help and after pressing the button I do need to unlock twice
not embarrassing at all I did same thing when I first picked mine up🤣. Just glad you sorted it
