Hi all ,I've been lurking on these pages for 2 years,  this is my first (desperate) post.
To cut a long story story short ,I kerbed my rear nearside wheel fairly hard ,but not to cause any serious damage to the alloy,(20 inch).
I had a 4 wheel alignment check ,all good up front and rear offside, however, the rear nearside is now showing toe in ,and is the cause for a slight pull to the left,(about 5  degrees steering wheel deflection to the right to correct).
The vehicle is a fixed beam arrangement ,so has no toe adjustment.
My question is this, what is the likely hood of the stub axle mounting being bent,(needing a new rear beam),or is it possible just the stub axle itself has shifted/bent or the whole beam has shifted on its bushings?
The camber is out too, readings as follows. camber 0.41% Toe 0.35%
Although I hit the kerb with a thump it did not seem enough to be catastrophic,
Any thoughts?
Thanks folks.
Dave.
Edited by Dragondrummer
Hi Dragondrummer,
Our 2007 Alphard was pulling left regardless of road camber. 4-wheel alignment showed Nearside rear (NSR) toe was 0˚05' [OK] but offside rear (OSR) toe was -0˚38' [definitely not OK]. There was no play in the rear bushes and everything looked fine. As you know, the rear axle is fixed, so can’t be adjusted. In the end I discovered that the OSR toe-out was due to a poorly assembled wheel bearing retainer - 2 of the 4 nuts were missing (nowhere to be seen I was told by our mechanic, but not in the hub, where they would have been if they had worked loose / sheared off), so the leading edge of the wheel was facing slightly outwards; not enough to notice initially, but gradually getting worse! There had been no work on the wheel hubs since being imported, so it seems this was a longstanding problem inherited from the Japanese owner, or possibly even from leaving the factory. I don't know if this will be relevant to your situation, but it might be worth checking the rear wheel bearing retainers to see if they’re aligned/secured.
Incidentally, as part of the process, I found two different sets of wheel alignment figures (take your pick…)
http://www.jltechno.com/en/alignment_specs.php?brand=Toyota&ModelName=Alphard/Vellfire:H10 Series:MNH10W&ModelID=610365
Alignment Data Lookup->Toyota->Alphard/Vellfire:H10 Series:MNH10W
Parameter
MIN spec
Standard spec
MAX spec
Front Total Toe
-0.17
0.17
FL Toe
-0.09
0.09
FR Toe
-0.09
0.09
FL Camber
-1.42
0.08
FR Camber
-1.42
0.08
Rear Total Toe
-0.25
0.25
RL Toe
-0.13
0.13
RR Toe
-0.13
0.13
RL Camber
-2
-1
RR Camber
-2
-1
Left Caster
1.67
3.17
Right Caster
1.67
3.17
Left SAI
N/A
N/A
Right SAI
0
0
And from our 4-wheel alignment specialist:
Toyota->Alphard H10 Series:MNH10W
Wheel Alignment Specification
Parameter
Minimum
      Maximum
Front Total Toe
-0.10
+0.10
FL Toe
-0.05
+0.05
FR Toe
-0.05
+0.05
FL Camber
-1.25
+0.05
FR Camber
-1.25
+0.05
FL Caster
+1.40
+3.10
FR Caster
+1.40
+3.10
FL SAI
+10.05
+11.35
FR SAI
+10.05
+11.35
FL Included Angle
FR Included Angle
Front Cross Camber
+8.40
+8.40
-0.45
+11.40
+11.40
+0.45
Front Cross Caster
-0.45
+0.45
Rear Total Toe
-0.15
+0.15
RL Toe
-0.08
+0.08
RR Toe
-0.08
+0.08
RL Camber
-2.0
-1.0
RR Camber
-2.0
-1.0
If you want to see, the complete thread is at https://uk.alphardclub.com/forums/topic/1041-pulling-left-rear-wheel-alignment-problem/#comment-7608
