Hi all afs light keeps flashing and saying afs off pressing switch on dash does nothing  anybody have ideas what is wrong
Unfortunately, the flashing indicates a fault.
The head lights should still work fine, but won't turn as you steer and change speed !
Thanks for info I know it’s to do with lights not moving as I turn but I am looking for info on fault i.e where to start looking for fault thanks for your help
Sorry, I don't have the faintest idea where to start.
I seem to recall a previous response indicating the system used several sensors, all interlinked through an ECU.
Could it be related to ABS? Mine was faulty and the AFS light came on flashing. It stopped flashing when ABS was fixed. Just a thought.
Just a suggestion check the headlight bulbs haven't blown, this does give a AFS fault
Hi. Managed to track cause off fault   Broken link arm on rear axle offside for levelling headlights repaired and afs fault gone. Thanks for all your help and advice
Well done.
Thanks for letting us all know.
  • 8 months later...
what was wrong with ABS?   I have it as well
Mine just started. Have seen same result on You Tube. Will try it . Cannot see which fuse, it can be unless someone else can show me. Not on my owners manual. (JPNZ Manuals)  Thanks
