Orange engine warning light.
Hi,me with engine light again.Alphard 2005.2.4  car runs super.apart from 1 thing.Approx every 400 miles engine light comes on.then looses power.turn off ignition  turn back on runs perfect again.Had MOT,yesterday and replaced new spark plugs and coils.i thougbt while at it i would have a new o2,censor fitted which by way it was £170.00.When i drove to MOT centre it drove,super.when new 02 censor was fitted and i drove home engine warning light was on and dove like a pig.just about got home.spent all together £520.right back to were i started Any help or suggestions,app.thank you in advance.Phil.
  • Sad 1
Link to comment
Share on other sites
There is only 1 o2 sensor 2.4 that's the rear one the front sensor is a fuel ratio sensor sounds like they fitted wrong sensor on the front you need to find out what they fitted easy way to do that ask garage was both same part no.s fitted if they say yes they fitted wrong one on front
  • Like 2
Link to comment
Hi. Take it back, and/or get a second opinion first!
Link to comment
Hi, sorry to hear your still having problems, Im not a mechanic, a quick look up on youtube gave some potential problems that will set an engine light in the order i found on the video.
1/ mass airflow sensor dirty or faulty (+ check air filter and pipework for leaks)
2/catalytic converter fault-Full!
3/o2 sensor /sensors
4/ plugs & coils
5/ fuel cap seal damaged
an obd11 reader might help find a fault
i would also clean or  replace a "pcv"  crank case vent valve.
+ apparently cvt gearbox and speed sensor faults can also  set an engine warning  light
 Hope you can find a good mechanic to fix.
Link to comment
Hi,picasso.Thank you for help.4 machanics could not tell me what you told me in 2 minits.Thankyou very  much.Going to get sensor changed.thank you.Phil.
Link to comment
Hi,reg num,is  LK05 VEP.thank you once again.Could you please tell me tyre presure for my alphy.i only no i.e 25 or 30 etc.The british way.And should i use super premium or sta dard fuel.Hope you dont mind me picking your  brain.Thank you once again for your help and nowledge.Phil.
Link to comment
The JPNZ Owners Manual specifies 33 psi.
There is a very lengthy thread in this Forum on E5 or E10.
Search for E5 E10 in the search box on your home page
I respectfully suggests you read it as there is quite a difference of opinions, including my own.
Link to comment
I think you posted an engine warning light problem thread before. The advice then was to buy an OBD reader. Did you get one in the end?
Link to comment
On 6/8/2023 at 7:29 PM, Picasso said:
384960138126
Yes i did.best £50 i ever spent.tha k you for advice.In fact would like to thank everyone for being so helpfull.I  would advise every club member to by one without any hesitation.And Picasso was absolutely correct wben he said iput the 02,sensor were i should have put the fuel sensor.Thanks to everyone for there help.Phil.
Link to comment
That's great so what is the code reader telling you about the cause of the engine light this time?
Edited by Geralt
Link to comment
Hi,Geralt was showing.02 sensor not operating .I actualy put the 02 sensor in the wrong bank.Silly me.Our member Picasso,said exactly that.100% right.
Link to comment
  Only 75 emoji are allowed.
