Hi, seems the Alphard Hybrid is one of the most popular models for catalytic converter theft...can anyone advise me on the best anti theft system to fit?
Thank you
I also have the same question.  Has anyone got any recommendations for a cat lock for an Alphard Hybrid please. I contacted Toyota locally to me and they said one hadn’t been made for this model, but I understand there are alternatives. Thanks for any advice.
  • 10 months later...
Catloc is Sold Secure Gold rated. The only snag is that they don't have a model specific for the Alphard.  They do a couple of generic models but you'll need to measure up and check that there's some anchor points.
https://catloc.co.uk/shop/?wpce_search=1334&post_type=product
When I get round to measuring mine, I'll publish the dimensions.
I thought Alphard having very little ground clearance (160 mm?) is immune to catalytic convertor theft. Is that not the case?
Does 3.5l v6 or hybrids, at their cats same? Or one is more precious?
160mm is not low to the ground. But..
Many Alphards are wearing big wheels and low profile tyres.
That tends to lower the car considerably.
Depending on the rear valance fitted, the rear clearance can be much more.
As the cats are resold for quite large sums, a jack would do the trick !
That tends to lower the car considerable.
On second thought might be best to secure it 👍
If anyone found suitable cat make model for gen 2, please share the link / image. Cheers 👍
