Hi. I have a 2008 2.4 Vellfire and have just fitted new rear discs. Since then the parking brake pedal has moved lower toward the floor.Β
Is there any adjustment on the brake cable or shoes on the parking brake? Or is it that I need new shoes or cable?
Β
John Harrison. Wirral
My 04 Alphard has a similar problem in that the pedal is needing to be pressed further and further.Β  How do I adjust it please?
Take the rear wheels off the discs have inboard drums with mini shoes inside . Locate the rubber bung on the face of the disc/drum (face the wheel bolts too) . With handbrake off spin wheel so hole is at the bottom . Insert flat blade screwdriver and feel for an adjustable wheel between the handbrake shoes. Spin it until the wheel locks on then back off until it spins with a little drag .
  • 4 months later...
Spot on πŸ˜‰ thanks πŸ‘Β
