Hello
I have a Funky Ram converted 2008 ANH10 Alphard that you converted in early 2022. The battery charger has stopped working. On removing it from the vehicle I have found that it is a 24 volt charger. Could you please tell me why a 24 volt battery charger was fitted to this vehicle which has a 12 volt system. The model number is BC2410. Many thanks.
10 hours ago, Charlie Brown said:
Hello
It isn't.
Read your other thread for my advice.
The relay does not charge anything, but it does connect the alternator to the leisure battery if the main battery is holding a significant charge.
Hello
IF this message is intended for Funky Ram, you should send them a personal message; that way they will see it and read it.
I doubt, as a business, Funky Ram trawl through all the Forum messages so they may never see it.
