Engine light.
Hi ,thank you so much for all your imfo,wich was bang on.I cannot beleive how well my Alphy is driving.I added catalist and sensor cleaner,as you advised.So much more poke in the acceleration.No more engine warning light.I went full hog,and had new spark plugs new coils,new fuel sensor.Fantastic.Many thanks for all your help.Going to run up to Norfolk tommorow.Kind regards Phil.
This post is for picasso.I did something wrong on sending .
Hi, which cleaner did you use?
Hi,the cleaner is Mannol Catalyctic
Converter cleaner.450ml.Approx,£10.00.Hopethis helps.
Hi, lee,hope i got your name right.me again hope you dont mind.Mistery,as you now ,have had new bank sensor 1,renewed,spark plugs and coils.Added catalic cleaner.I drove from Essex to suffolk and back wednsday.Could not drive better.lodes of poke.up hill lovely.very very smooth ride.loads of acceleration.Very responsive.just as i reached home engine warning light came on.Still driving A.1.put on computer.said bank one weak mixture.I whent out just now to read computer.and it said no falt codes .i did put some e,10 and e,5 petral.could it be just stabelising with theengine .should i just ignore appr any advice.thanks .
I personally put another bottle cat cleaner in can take a couple bottles to give it a good clean you did the right thing giving it a good drive you probably still got some dirty carbon in the system you got name right I'm more than happy to give you advice where I can a dirty maf sensor can give you false readings
Edited by Picasso
Name
