kristoff Posted June 25, 2023 Posted June 25, 2023 I am the fresh owner of velfire and about to go for trasn flyid change . I am aware book says something like 6.5 litres but we all know that torque converter does holds some and lucky if i do drain half . Now is the question someone that did it Howany litres should i buy ot top of the strainer and if the gasket does survive?
R4v3n Posted June 26, 2023 Posted June 26, 2023 As the gearbox is the same on the Camry, I followed this video (and mixed it with a bunch of others) : I followed the Toyota technician software too, and ask a friend of mine who's Toyota mechanic how they do the flush on this type of transmission. In resume, for me the most important is : - Take a graduated container to have an idea of how much you got - Don't forget to remove the overflow tube when flushing - Replace the filter - Don't forget to put in back the overflow tube - Overfill a bit - Use a laptop with Techstream to get the fluid temperature, then you'll be able to make the level accurately.
kristoff Posted June 26, 2023 Author Posted June 26, 2023 Bit pointless as i know my trade just the fact that i was after amount of fluid that drains on replacement 🙃
Register a new accountSign in
