We are just back from a 2600 miles trip through France and in to Italy back up through the alps .
It was a great holiday , however the Alphard has come back with a bit of battle damage !
one of the radiator fans seized in the south of France  , not good in the blistering heat .
I reckon the alternator isn’t putting out enough volts , as mh dc - dc charger stopped working .
Then to top it all off when back in Blighty we hit a huge pothole on the A1M , which burst the front strut !!😡
The thing is it came from Japan on lowered bilsteins , I’m having a real time finding a replacement .
I might have to replace the whole lot !
Apart from all this  we had a great time 😂
Is your alternator a 3 or 4 pin plug ? I have a brand new one in the garage (3 pin connector) sent to me in error and never returned it ! Mine was a 4 pin connector. It was £180, so could save you a few quid ? 😉
Thanks for the offer , I will check it out to see if that is the problem .
lll need to get the multi meter out and see what is going on with it .
I’ll be in touch if the alternator is knackered
thanks
I got my multi meter out , alternator charging as normal , leisure g battery charging as it should .
Totally weird ,it wasn’t charging at all on holiday   , do t understand it .
