Hi all,
I have a Alphard 2013 3.5 V6 4WD
My AFS light flashed on and off. I have changed the sensor on the rear axle and when the headlights turn on in the evening. It starts to flash again.
Any idea what it could be? Does it need to be out into a code reader to clear any fault codes or any other ideas what else it could be will be a great help
Many thanks
GGH25-R
Donc you have a PC with Toyota Techstream ? First thing for me would be to test the AFS ECU with Techstream.
23 hours ago, GGH25-R said:
Hi all,
Many thanks
GGH25-R
Could you confirm that you have the correct HID bulbs fitted, and not aftermarket LED ones?
Some of the aftermarket 'upgrades' are heavier at the rear due to heatsinks or fans or additional cabling.
