Hi Can anyone tell me if our 2.4 Alphard 2007 has a belt or a chain please? Our son just had a belt fail on his Citroen and now we're worried. Hopefully our lovely car has a chain!
Edited by Jenny Smedley
Geralt is correct.
For the benefit of V6 owners; it it only the 3 litre V6 that has a belt (not the 3.5).
However, the engine is a non interference design . So what ?
If the belt breaks on a non interference engine the valves will not hit the pistons and wreck the engine.
You will break down, and you will need a new belt and need to get it fitted and timed correctly.
The above is not true if the engine 'drops' a valve.
Either way, if you have a V6  get the cam belt changed, if needed, or risk a stranding.
Hi. My 2008 (AH20) Vellfire 2.4 has a timing chain. I'm pretty certain all the 2.4 models have them?
Hi. CHAIN! You're safe!!!
Best wishes
Just a small point.
Generally speaking.
Chains don't last forever, despite some Toyota engines doing so.
Chain tensioners tend to have a shorter life than chains and engines.
I need to research whether the 2.4 litre engine is a non interference design.
